Hi @m.roszak,
Any news on weather conditions?
From what I can see it is still mixed up. Is there a chance when this is finalized that you give us a list of available weather conditions and weather condition codes?
Thank you!
Not yet, its in the backlog on pretty high priority but its just not that easy...
Its seems simple but any changes in this area may/will affect all the interfaces (old app, new app, webUI, scenes, scenarios, lua scenes) - this is something on the shelf for now.
For sure we will clean this up at some point but currently there are more urgent topics in progress.
    Thanks @m.roszak for explanation.
    It really isn't that much important except that it does influence weather providers icons in the Yubii app. They are not same as on the web GUI.
    Maybe we can figure out together as a community list of the desired condition types for the weather icons - as an ultimate list... for the future.
    I think that we can even make a poll on that ;)
    To be honest I like to have it simple as it is now, just maybe add few missing ones. I will check and provide a list.
    Just one question: is there any limitations or boundaries what is worth to have? For example: icons and conditions for sunny/clear and partly cloudy to have different icons for day and night time?
    Due the nature of current digital language system very small details on the icons won't be possible, so for example "drizzle", "light rain", "moderate rain", "heavy rain", "storm" does not make much sense - no clear visible difference between icons and all those would need to be multiplied by number of specific weather condition types (snow, hail, sunny, cloudy etc...).
    As for night/day - I would go for something generic here but if the voice from the field will be strong on getting those I will try to figure it out with UX/UI designers to make it happen.
    I agree. Keep it simple with just most needed weather conditions.
    There is another thing I need to point out. I noticed that weather on dashboard is not updated as expected. If I select my Tempest Weather provider which updates every minute, this is not reflected immediately on dashboard weather. Is there a limitation how frequently dashboard weather is refreshed?
    Just to add, dashboard weather is refreshed if home page is refreshed in browser, so I do not refer to browser refresh, but to automatic refresh when home web GUI page is shown in browser tab.
    Edited by Sankotronic
    • 3 months later...
    @Sankotronic
    @m.roszak
    I live in Genova, where the local geography makes weather forecasting especially tricky: mountains right on the coast, narrow valleys, strong wind channels and very local micro‑climates. Generic global models like YR, OpenWeather or AccuWeather often miss important details here, especially for rain, cloud cover and wind. After a lot of testing, the Open‑Meteo ARPAE ICON‑2I model turned out to be much more accurate for my area, because it is designed for Italy and handles the complex terrain far better. That’s why I built a custom Weather QuickApp based on ARPAE instead of using the default provider.
    While developing this QA, I discovered that the HC3 weather system has some important but undocumented constraints. Internally, it uses a Yahoo‑style icon set, so WMO or Open‑Meteo codes must be converted before icons will display correctly. On top of that, custom Weather QAs only support six WeatherCondition values: clear, cloudy, fog, rain, snow and storm. Any other value, including things like “partlycloudy”, will not show an icon. This forces anyone using modern weather APIs to compress dozens of detailed condition codes into just six categories if they want consistent behavior on HC3.
    There is also a difference between system devices and custom QAs when it comes to properties. In the default YR device, the Pressure property exists internally and is updated by the system, even though it is not shown in the YR UI. In custom Weather QAs, however, Pressure is not part of the available property model at all: it cannot be added, declared or updated. If you want to use pressure in a custom QA, you have to implement your own storage and display logic, for example with variables or custom labels. So the platform supports more data than it actually exposes to custom developers.
    Because of this, building a robust custom Weather QA on HC3 requires extra work: mapping codes, reducing conditions, and recreating some functionality that already exists internally. It would be very helpful if Fibaro provided clearer documentation about the internal weather model, the supported WeatherCondition values and which properties are available (or could be made available) to custom QAs. Even small improvements in this area would make it much easier to integrate high‑quality local models like ARPAE and would help keep system devices and custom QAs consistent across the platform.
