Some major bugs found
1. Thermostat heads (Fibaro) doesn't follow the climate schedule panel setpoints. / i didnt test with other thermostats yet
2. Fibaro radiator head's "heatRequired" never changes, so we can not drive heatpumps according to this property value.
note: both were working flawlessly in engine 2. We have it in many many installations..
    Another bug
    Inclusion process stuck in loading screen
    /monthly_2026_03/image.png.1b359eb24e5502326f842a5a499b257c.png" />
    Hi Neo!
    We are currently investigating the issue you reported regarding the thermostatic heads. This issue is not related to the migration.
    As for the “heatRequired” value of the radiator head, we are already working on a solution.
    Kind regards,
    Ini
    W dniu 7.03.2026 o 11:09, Neo Andersson napisał:
    Another bug
    Neo,
    could you try adding the devices again and generate the logs while doing so? This will help us check exactly what’s going on.
    By the way - which devices were you trying to add?
    Best regards,
    Ini
    Hello, i am in contact with mr @D.Karczewski
    It was a Aeotec Sirene 6 device
    We had an issue wth forst migration. then i have sent logs to him. He found that some tone names have unsuppreted chatracters that might cause the problem.
    To proove this, i have exlcluded the device and tried the migration again. It worked. So i tried to re-add the device again, but it failed again.
    I think this is still caused by some tone names, but i can try it once again. So at which point shoul i download the logs? After the failed inclusion ?
    Becuase the inclusion never ends. Or should i donload the logs during th inclusion while the loading screen is shown?
    If the process gets stuck, please download the logs and send them to me - I’ll pass them on to Damian ;)
    Ini
    Ini
    I tried again..The process never ends. Here is the logs
    The issue has been submitted for analysis, and I’ve already passed the logs to Damian.
    Best regards,
    Ini
    Here i have some other problems
    System shows me available FW updates for devices..
    I started the update and it finished with "Completed" notification
    However, i see some warnings about reconfiguration see the picture
    also i noticed that even the process says its finished, in the device swagger i can still see that device is on 5.1 and 5.3 is still avaiable for it..
    What to do?? Do we need to manually reconfigure devices after FW updates??
    I tried manually reconfigure the device 237
    It ended up with all the childrens got new IDs !!!!!!!!! (parent stayed 237)
    Another issue
    Device stuck in FW update
    Another issue
    Reconfiguration runs forever for some devices.. and never ends..i can not cancel it, so i can not do anything about it
    This below is running more than 30 minutes
    /monthly_2026_03/image.png.dc9cc67f9c6d3069e132534c2e960e95.png" />
    Hi Neo,
    Could you please specify exactly which devices these were and whether they were mains-powered or battery-powered devices. I would also appreciate it if you could send the logs from the moment when the issue occurred.
    Best regards,
    Ini
    Yes - device IDs may change if something in the model changes. In practice, this is more likely for devices after migration. We are working on reducing the number of such cases in the next version of the system.
    This information that devices may receive new IDs is indicated:
    • on the Device reconfiguration tab, above the "Reconfigure device" button (it is also visible in the screenshot you attached),
    • and in the modal window with the warning message, which appears after clicking the Reconfigure device button.
    W dniu 9.03.2026 o 18:52, Neo Andersson napisał:
    Another issue
    Here we also need some clarification – please let me know exactly which devices these were. If there are battery-powered devices, they will almost certainly need to be woken up.
    What do you mean by "Which devices there were" ??? You can clearly see on the picture. Its the device 142. Reconfiguration stuck. Its not a battery device, its an implant.
    3 hours ago, Ini said:
    Hi Neo,
    Best regards,
    Ini
    Again, its on the picture..ID is 237
    You colleague have responded to this. Device shows Completed status but the update is still not yet applied until the reconfiguration happens..You also have the logs. I had to manually reconfigure the device and only after that the available update dissapiered (so the update actually got applied)
    I think in large system migration is a horror. We will not do it. We will use engine 3 only on new systems. Having a system with 150 moduls, and all the migration requires reconfiguration of all devices ..wll this is not a path we can afford. Its not only that its such a time consuming task (that it would need days to complete), but also our plugins all across the system are using already some IDs of devices. Reconfiguring every single device means they got all new IDs so our all plugins will crash. I have discussed this with your colleagues. This is not the way we want to go on existing large systems. Thanks
    So, the reconfiguration after the OTA is a Z-Wave protocol requirement according to the specification.
    As 3.0 is fully certified, its something mandated unfortunatelly.
    At the end, as @Ini stated - we are working on bulletproofing the reinterview (reconfiguration) of the migrated devices to keep the IDs if possible.
    Its not an easy job as migrating everything from one model to another (with filling the gaps from old model) is not an easy task.
