Completed the migration form Zwave 2.0 to Zwave 3.0.
In my case is night and day change. Now network is super fast. Didn't really expect this....
With 2.0 I always have in my network, with 35 devices,  a lot of failed communication, around 5/10 %, with 3.0 is 0 % since the update....
Fantastic
Edited by Fyase
  • Like 3
  • Fyase changed the title to Zwave Performance
Thank you for your feedback 🙂 We're glad to hear that the migration from Z-Wave 2.0 to Z-Wave 3.0 has brought a significant improvement in your network performance. We are continuously working on further development and optimization of the system.
Kind regards,
Ini
    Kind regards,
    Ini
    Hi @Ini,
    I was expecting an improvement in the migration only after moving my devices from S0 to S2...
    I'm quite surprise to have such an improvement just by changing the engine.
    Raffaele
    Fantastic
    Did you find same problems as @Neo Andersson
    Edited by cag014
    No, it works straight out with no issue....
    I then excluded some devices and add it back with S2 and it worked normally
    • 1 month later...
    I held my breath and made the much awaited shift to ZW3 engine (via5.202.54 beta)
    186 devices.
    Went fine - a few shutter devices that have been playing up now work perfectly after a reconfigure (which didn't help on ZW2).
    I am getting 404 errors when trying to reconfigure poorly devices (they were poorly before), which I dismiss, and try again, and it works.
    My only concern is that mesh rebuild (on the UI and as a function) has gone, replying on self-healing only - and so far I'm not seeing any improvements to number of devices with 3 and 4 hosts (unless my old device checker now lies to me...?)
    EDIT: mesh has settled pretty well. Super happy with this ZW3 shift. Nice job to the Nice/Fibaro folks
    Edited by NorthernRough
