After update i do not have the "Soft reconfiguration" or "mesh reconfiguration" for Z-wave devices buttons anymore.
Are those supposed to be removed?
Indeed, see for example here:
On 8/11/2025 at 10:34 AM, m.roszak said:
There are, in general, lots of changes pas few versions of 3.0 to improve it.
One thing you need to understand, mesh is something managed on protocol level (Z-Wave chip + Z-Wave SDK) - not by the client.
It does not matter if its 2.0 or 3.0 in this case, mesh is built and maintained automatically. Triggering mesh reconfigurstion just forces the procedure to be speed up, does not affect the overall performance in time as this is self-changing/self-healing process which is always in progress.
Mesh reconfiguration is not available on ZW3.0 in the same way it was on 2.0 - but if you like you can check the API definitions in swagger, you will see there some functions which may be interesting for you.
So maybe Swagger can help you out.
