I have 3 Greenwave 6 ports that doesnt send any power consumptions of connected units.
I tried to do a Reconfiguration on one of them and then it only registers as one binary switch...
I also have a Pop Keypad which works great before but also stopped working after upgrade.
When i try to reconfigure it, it seems to work (Adding successful) but i can synchronize the users pins anymore.
Before upgrade i could always set different pins/codes and then sync with the HC3.
If i use a block scene now, i get to the part where i can choose the keypad, but when chosing the "==" option to point to which user it should match, there is no option (Probably because i couldnt sync the keypad with HC3).
Anyone else that has these  devices and has issues?
We’d like to review this case in more detail. Please send screenshots of the problems and device numbers. Please also send the serial number of your hub in a private message and make sure support access is enabled. This will help us diagnose the issue more efficiently.
Best regards
    Thanks!
    I will send more details in a mail to you.
    BR
    • 4 weeks later...
    Any updates for both of these?
    I have tried to remove/add the pop keypad several times but cant get it to work.
    The "sync" button is not present anymore which it was before so right now i cant unlock/lock my home unless i use the app and my kids doesnt use the app..
    The greenwave powernode is also not working and i have several of these..
    BR
    Jimmie
    i think it is because accessControlEvent seems to be broken in zw3 engine
    Thanks @tinman!
    Then i guess im not alone with this..
    BR
    Jimmie
    Hello @747,
    We’re looking into this, and it’s likely that we’ll be adding support for this device soon.
    Best Regards
    Thank you!
    @Support FIBARO, any updates regarding the greenwave powernode problem?
    BR
    @Support FIBARO, Have you been able to fix the greenwave powernode issue yet?
    I have a lot of scenes that are using my powernodes (measuring power consumptions on different ports).
    BR
    Jimmie
    We’re still working on this and will update you as soon as we have any news.
    Best Regards
    • 4 weeks later...
    Best Regards
    Hi again,
    I reconfigured one Power Node after V5.203 update but still no power consumptions for each port so i guess this fix it wasnt included in V5.203 update?
    Could you please prioritize this for the next update?
    I have, as i said, many scenes /QuickApps which triggers on several ports of these powernodes and my home isnt working very good as it is right now...
    BR
    1 godzinę temu, 747 napisał:
    Hi again,
    BR
    Please provide:
    • the exact device model: manufacturer name, model, and version,
    • its "deviceId",
    • the Node number in the Z-Wave network.
    Additionally, please perform the following steps:
    1. Reconfigure the device,
    2. Right after the reconfiguration, send us the logs.
    Optionally, if possible, please remove the device from the network and add it again. After that, check how the device appears in the interface.
    After removing and re-adding the device, we will also need the logs.
    Best Regards
    Here is the Manufacturer Name, Model and version:
    /monthly_2026_05/image.png.66d5944c965fd97fe583df41ece7a07a.png" />
    These are the device IDs:
    I just did a reconfiguration.
    I have sent you the logs in a private message (Please let me know if you wanted other logs)
    BR
    Edited by 747
    • 1 month later...
    We'd like to get back to the topic we discussed earlier and take a closer look at it.
    Would it be possible for you to share the hub with us for analysis? Please also let us know which device (deviceId) we can use for testing. Enable full remote access as well so that we can investigate the issue thoroughly.
    Thanks, and we'll be waiting for your update.
    BR
    I have enabled remote access now.
    HC3-00000454
    Im not home at the moment but please check if you can resolve the issue without having to go back to ZW2 engine.
    Br
    Jimmie
