I found an inconsistent termperature zone reporting between Yubii app and HC3 console. The heat valve however are working correctly following HC3 dashboard.
Here what I found.
For ester holiday I set profile to Away. This profile set the climate zone to OFF.
In the HC3 all is report correctly and the valve are set to OFF
The inconsistent behavior is on Yubii APP where climate is a mess.
Not a big deal since valve are working correcly but it need to be fixed anyway
Raffaele
