I’d like to share a small application that searches for a specified string in the Lua code in all quickapps stored in hub.
The text to search for should be entered in the SEARCH_TEXT variable. Case sensitive.
If there will be interest, I can expand this program further whenever I have some free time.
    This is an extended version.
    It supports regular expression in search pattern - and, or, not, () and wildcards, like: &, I, !, (), *, ?. The regex parser is taken from
    project. Please see there for reference of regular expression. One change is that wildcard is not necessary at both ends of phrase.
    Ex.
    var & (!tonumber | tostring)
    This lists all QA files containing the phrase var and either not containing the phrase tonumber or containing the phrase tostring.
    Also 'whole word' and 'case sensitive' buttons are added.
    As anyone can see, even a needle can be found...
    Second feature is ability to compare Quickapp states - recorded once to current. Press 'Make image' to generate a snapshot of all Quickapps (not scenes) in the hub.
    Press "Compare" to see the structure of all QAs and their files, as well as which files were modified, deleted, or added from time of snapshot generation to now.
    Edited by Łukasz997
