Here is a small QuickApp that can be very helpful for developers. Many times, when we needed to solve problems remotely, we had to check certain values in Swagger. This usually meant quickly writing some Lua code just to retrieve the device’s JSON data.
This small QuickApp allows you to simply select a device and access any information you need to inspect.
Note: untick the new view for mobile application checkbox
Edited by Neo Andersson
1. Sort the files displayed in some stable order, so that ex. id is always at top, type second etc... it slows the usage down if you have to hunt through the whole list to find the field you are looking for...
2. [Reload] I would expect to just update the current view displayed. Now it clears the device selected and it has to be reselected.
3. Why encrypted?
    3. Why encrypted?
    1. Devices are sorted by ABC. And anyway you have searchbox in every dropdown. Or am i not getting you? You dont have to print the entire JSON, you can multiselect some property fields that you re interested in etc..But feel free to adjust it to your liking.
    2. Reload is for plugin reload. It serves for situations when api.get/devices needs to be refreshed (your system got new devices or some was removed)
    3. Encrypted because i just uploaded it to here when we were uploading it to customers, and there we use encrypted versions. I did not think even about this. This is a simple QA, nothing out of ordinary, especially nothing new for you :-), but i am attaching the fqa too.
    • Like 4
