Roller Shutter 4 - venetian blinds single press
I have multiple Roller Shutter 4 modules mounted for controlling Venetian blinds. Mostly automations are doing their job and I do not need to press any button. Anyway, when I need to, I would like to properly set single/multiple press behavior (and for the lights also). I am using two (up/down) monostable switches.
Right now, if I want to close the blinds and I press the close button, blind level goes to 0%, slats angle goes to 0% and slats open again to horizontal position. If I want them to stay closed I need to hold the button. How do I set it to stay closed after single press? Or maybe, if slats angle is 90 degrees and I single press the button, it decreases by 30 degrees, to make some shading etc.
As far as i know, it is not possible. Slats will keep the last potision they had. So if you move the shutter to some position, when it stops moving, it restores the state of the slats to the position where they were. You need to set slats position separatelly.
I think some years ago i had a topic about this, and if i remember correctly this behaviour can not be changed.
