Why API REST and api.get() don't return the same info sometimes ?
Hello
I'm working on a QA involving icons and I'm displaying some of them in the Webview.
As I was looking for a way to retrieve the path of native icons, I was surprised to notice that REST API for icons (BOX_IP/api/icons) returns the full ICONS.JSON (with ALL icons data, both native and custom), while api.get("/icons") only gave me a little info about 19 "special" icon sets (mainly FGKF, FGGC, FGPB, FGCD, usbPort).
I immediately compared REST API for devices (BOX_IP/api/devices) and api.get("/devices") : they both return the same info. I get all my devices and their info both ways.
Than I compared REST API for rooms (BOX_IP/api/rooms) and api.get("/rooms") : they both return the same info again. I got all my rooms and their info both ways again.
So I my quest for native icons info through api.get() I'm wondering whether I did something wrong or if this a voluntary restriction for icons ?
I can't find further information through the swagger.
thanks
16 hours ago, fel-x said:
Hello
thanks
If you set the header
["X-Fibaro-Version"] = "1"
you get the restricted return, plain list of icons. It seems like api.get sets that by default.
If you set it to
["X-Fibaro-Version"] = "2"
you get the full list divided up on device/room/scene
It doesn't seem like the swagger api honors the x-fibaro-version but always calls with "2"...
But if you try
    Thanks @jgab
    This works quite well. I was tricked by the swagger that never returned the full list.
    You maybe inverted ["X-Fibaro-Version"] = "1" and ["X-Fibaro-Version"] = "2" in your explanation I think, because my swagger sets 'X-Fibaro-Version: 2' whatever I try.
    Anyway, the net.HTTPClient() works well !! 👍
    And you should quickly erase your base64 encoded password from your reply here above 😵
    Edited by fel-x
    Hello @jgab
    I successfully combined both methods thanks to your tips
    My Icon Customizer QA is now ready (after a lot of testing) and was approved on the marketplace.
     in case you're interested
    comments are welcome
    thanks for your help in various forums
    Edited by fel-x
