Low electronic whistle sound from wall keypads in silent room
I have two wall keypads connected to my Yubii Home system.
In a completely silent room, when the keypad is powered, I can hear a very light high-pitched whistle / electronic hiss coming directly from the keypad.
It disappears when power is removed.
Questions:
  1. Is this normal behavior?
  2. Could it be LED backlight / internal converter coil whine?
  3. Can brightness or LED settings reduce it?
  4. Could power supply quality cause this?
Thank you.
Probably a question for the manufacturer. Are the wallpads Fibaro branded?
No, they are not.
And in cheap electronics its typical that coils are noisy.
