Hi @m.roszak,
Before this update lights color controller ring was always dark regardless if light is turned on or off.
In this last update rings are always filled with some color even when light is turned off:
When lights are turned on then status is OK. Now just to get ring to go back to dark when light is off ;-)
Thank you!
its grey, not dark - true... It keeps the color from the white theme and should switch to almost black.
@Support FIBARO - take a look at it ;)
haha and I thought gray had been chosen as a clearly visible indicator - together with an “off” status - to represent “off,” since most people wouldn’t recognize anything between about 1–5% anyway
    i think just off color is swapped for dark and light theme :-P
    Good thing its fully functional, just minor UI bug with playing with the color theme of the app.
    Whats wrong in the following pictures:
    Dark grey on light theme is almost acceptable, but light grey on dark theme definitely looks like light is turned on.
    Don't see why can't be black on both themes when light is turned off. If it is for visibility, then make white thin border on dark theme and dark blue on white theme without shadow ;-)
    Regarding functionality, yep, it is showing same light color as on web GUI 👍
