I have a doorsensor (using a binaire input module from Weinzierl: KNX IO 411.1 secure
I've connected a doorsensor to one of the inputs and defined it as a door/window sensor and connected it to groupaddress with 1.019 window/door. In the KNX logging, it shows open and close.
But on the Fibaro side, nothing is coming in and when I update the sensor on Fibaro (to open/close sensor), I get the message below.
What is the problem here?
[30.04.2026] [10:46:29] [DEBUG] [KNX]: [ZmqServer] Received: {"id":0,"jsonrpc":"2.0","method":"configure","params":{"deviceId":24,"properties":{"categories":["safety","other"],"dead":false,"deadReason":"","deviceControlType":1,"deviceIcon":513,"deviceRole":"OpeningSensor","icon":{"path":"/assets/icon/fibaro/DoorSensorV2/DoorSensorV20.svg","source":"HC"},"knxGroupAddresses":{"state":{"command":"","dpt":"1.001","status":"1/4/10"}},"lastBreached":0,"log":"","logTemp":"","manufacturer":"","model":"","saveLogs":true,"supportedDeviceRoles":["Other","BinarySensor","SecuritySensor","AlarmZone","MotionSensor","OpeningSensor","PositionSensor","SafetySensor","RainSensor","HeatDetector","GasDetector","SmokeSensor","CODetector","LeakDetector","FireDetector","PresenceSensor","VibrationSensor"],"userDescription":"","value":false}}}[30.04.2026] [10:46:29] [WARNING] [KNX]: [ZmqServer] method unsupported[30.04.2026] [10:46:29] [DEBUG] [KNX]: [ZmqServer] Sending response: {"id": 0, "jsonrpc": "2.0", "error": {"code": -32601, "message": "method unsupported"}}
Regards, Willem-Jan
    Okay, I found out that secure communication is not working.  When change the communication to unsecure, it works.
    Is there a plan to add the functionality too?
    Yep, its on the roadmap alongside with tunelling feature :)
