I have a Zennio ZIO-KESP energiemeter.
It shows data in de logging at KNX:
Eigenschap    Waarde
Naam Doel    Voltage L1
Type    GroupValue_Write
Is Data Secured    False
Is Herhaald    False
Frame-formaat    Standard
Hop count    6
Prioriteit    Low
Ruwe waarde    436A4000
Datapunttype    14.027 electric potential (V)
Geformatteerde waarde    234,25 V
Eigenschap    Waarde
Doeladres    5/0/0
Naam Doel    Verbruik L1
Is Herhaald    False
Hop count    6
Prioriteit    Low
Ruwe waarde    41400000
Datapunttype    14.056 power (W)
Geformatteerde waarde    12 W
and Fibaro:
[30.04.2026] [11:45:47] [TRACE] [KNX]: [KNX] Report from 5/0/1 : (67, 106, 87, 10)
[30.04.2026] [11:45:47] [TRACE] [KNX]: [KNX] Report from 5/0/0 : (65, 64, 0, 0)
Both inputs in Fibaro are 9.xxxx float
Both as multi levelsensor. One as Electricitymeter and one as Powermeter
How can I make this visible in Fibaro as Voltage and W?
The same, I'm still looking for an option to send kWh through.
Thanks in advance.
Regards, Willem-Jan
Edited by Willem-Jan
Added information
Hello @Willem-Jan,
Yubii HomePro (Fibaro HC3) does not support DPT 14.x (4-byte Float), yet. So these will not work, yet. I am using MDT energy meter.
Maybe custom Quick App would work with 4 byte Floats, but someone needs to write it, till Nice development creates support for it.
I reported it in topic
    Hm, bad news.
    I have to order new hardware or write a quickapp.
    What about temperature and humidity sensors?
    I'm planning to use modbus sensors connected to a KNX modus gateway (Weinzierl) ?
    Temperature is typically DPT 9.xxx float - its supported.
    In humidity its exactly the same.
    /monthly_2026_04/image.png.47d0f35481e277c8995ac2609bcd1e9f.png" />
