marcin12 0
Hi everyone,
I’m having a recurring issue with Fibaro Heat Controller / FGT-001 devices and I’d like to know if anyone else has seen similar behavior.
My setup:
Z-Wave JS US + Zooz ZST39R (Z-wave 800 network)
Firmware versions tested: 4.9 and 4.10
Devices already included in the Z-Wave network
Mounted on radiators
Charged via micro-USB from a power bank
The issue happens during/after charging.
What I did:
The Heat Controller was mounted on the radiator.
I set it to OFF before charging.
I connected a power bank via micro-USB at around 8:00 PM.
The device started charging normally.
During charging, Z-Wave communication still worked.
Around 4:00 AM, Z-Wave JS UI showed the node as alive, and the device reported 99% battery level.
Around 6:00 AM, the LED was pulsing green, so I disconnected the power bank.
After that, the device no longer communicated over Z-Wave.
At first I thought the device lost communication after I disconnected USB. However, after checking the Z-Wave JS driver logs, it looks like the problem actually happened earlier.
The logs show that during the night, until around 3:34 AM, the node was constantly sending Power Management Notification reports. It repeatedly alternated between:
This happened almost continuously, roughly every second / every few seconds. The log file from the night was around 19 MB, and about 99% of it was traffic from this one device.
Around 3:34 AM, the node stopped communicating. So it seems the device became unreachable when charging completed, not when I physically disconnected USB at 6:00 AM.
I saw the same problem on another FGT-001 as well, running firmware 4.9. So this is not limited to one device.
After the problem occurred:
the node still existed in Z-Wave JS UI,
the device locally still indicated that it was included in the Z-Wave network,
ping failed,
commands failed,
the valve did not react to Z-Wave control,
the built-in Z-Wave range test showed red, meaning no communication with the controller.
So this does not look like exclusion or factory reset. The device still thinks it belongs to the Z-Wave network, and the node still exists in the controller. But after the charging-complete transition, it becomes unreachable.
I find it hard to believe that normal charging should require removing the device, entering standby, recalibrating, moving it close to the controller, or doing a full exclude/include. It should simply charge and continue working.
Questions:
Has anyone seen this behavior with FGT-001?
Is repeated
Battery is charging/idlereporting during charging normal?Is this kind of Power Management Notification flood expected?
Is this a known firmware issue in versions 4.9 / 4.10?
Is there a recovery procedure that does not require exclude/include?
Any advice, similar cases, or confirmed recovery procedures would be appreciated.
As of now, the only reliable way to use these Fibaro Heat Controllers in my network is to re-include each device every time it is charged.
This makes no sense to me. If this is really how Fibaro designed this device to behave, I will probably fall back to Eurotronic Spirit Z-Wave devices instead.
