Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Main features:
KNX integration
From now on, your KNX system can work even smarter thanks to integration with our Yubii Home Pro and Home Center 3 hubs. Gain full control over lighting, switches, RGBW controllers, blinds, shutters and sensors within one unified ecosystem.
Migration of Z-Wave engine from 2.0 to 3.0 version (BETA)
In this version of the software, it is possible to migrate the Z-Wave engine to version 3.0. Migration will allow you to take advantage of all the features of the new Z-Wave engine, including using Smart Start, better generic support for Z-Wave Plus devices and the availability of Security S2, which can be considered the first fully secure communication method for the Smart Home.
Smart Start
From now on, you can use the Smart Start function using QR Scanner in Yubii App. This function will allow you to add devices to the system even faster using binding process.***
What's new:
Devices
    Improved display of device families on the device list so that child devices are always located under their parent device.
    Added Operating State indicator for Linked thermostats.
    Added direct access to KNX communication (both sending and recieving packets) from the API.
Elero
    Integration with ELERO Lighting Receivers: TTDTW-E (Combio-868 LI W), TTDRGBW-E (Combio-868 LI RGBW),  TTDW-E (Combio-868 LI PW).
Energy Panel
    Integration with Tibber monitor to allow automatic rates update for Energy Panel (Available only for addresses located in Germany, Norway, Sweden or the Netherlands).
Gateway connection
    When the Slave hub is turned off or there is no connection, the devices added to it are visible as inactive (dead) in the Master hub.
    Enabling Support Access and Remote Access on the Master hub also enables access on slave hubs.
Nice*
    Upgraded NICE chip firmware version to the newest one.
    Added the option to disable the sun impact (setting the value to 0 lux in parameter 10) for the Domi WSC device v3.9.0.
    The default values of parameters 1, 3, and 10 have been changed for all versions of DOMI WSC devices.
Other
    Added the information about the zone where the alarm occurred.
    Verification of the checksum when downloading the update file at the beginning of the process instead of at the end.
    Removed PKO Assistance plugin from the system due to official termination of cooperation.
Scenes
    Added a new scene activation/deactivation block as an action in block scenes.
    Added possibility to enable/disable local and remote device protection via scenes and profiles.
Z-Wave
    Adjusted parameters templates for sensors to reduce number of reports for various devices.
    Fixed setting of parameter 5 for the MCO Home MH7H-EH device.
    Improved clearing Z-Wave network reset procedure.
    The ability to manually add parameters at each endpoint.
    Improved Z-wave3 engine resilience to communication issues in Security S0.**
    Support for Z-Wave 3.0 in Installer App.**
Bug Fixes:
Backups
    Fixed an issue where the “Update and restore” buttons for backups with higher software versions were inactive.
Climate
    Fixed an issue where the schedule was not cleared from the Heat-Control/Fibaro Heat Controller when it was removed from the climate zone.
    Fixed an issue where an added temperature sensor was removed from the climate panel when editing other settings in that panel.
    Fixes an error occurs after deleting a device in the climate schedule.
    Fixed issue with saving climate zones in some cases.
    The FGT thermostatic heads are not synchronised with the schedule.
Devices
    Fixed an issue where the Color component view was not updating correctly.
    Fixed an issue with changing icon for Dahua cameras.
    Improved performance for the DoubleDimmer-Control binding Wizard.
    Fixed a problem with KNX device configuration caused by the lack of support for diacritical marks in device names.
    Fixed an issue with function settings for Z-Wave devices with an empty template during the binding process in the mobile application.
    Fixed incorrect KNX Bridge connection status after IP change.
    Restored missing temperature graphs on FGT device version 4.10.
    Fixed the appearance of the dialog in the user interface for BiDi-Awning and AV Controller.
    Fixed the display of svg icons in the mobile app for Sprinkler and NICE Siren devices.
    Fixed problem with CoolAutomation plugin to receive correct feedback/status in mobile application.
    Fixed UI for Advanced Configuration for the Keyfob lock button and unlock sequence.
    RGBW device doesn't control properly the color setting in specific actions sequence using the picker.
Elero
    Fixed color component values for the Elero Lighting RGBW device.
    Fixed the appearance and behavior of the Elero Lighting RGBW device icon in the user interface.
    Fixed invalid settings for temperature color in profiles for the Elero Lighting RGBW device.
    It is not possible to control Elero Lighting RGBW after pairing it with the system if the LED output is turned off during finishing binding procedure.
Gateway connection
    Fixed errors and incorrect display of options in association settings.
    Fixed IP address validation in the Gateway Connection tab.
    Wrong backup type while software update for slave hubs.
    Devices from different phisical networks are listed as a target destinations in associations.
KNX
    Fixed a KNX connection error that occurred when reconnecting after a long period of time.
    Fixed problem with reconnecting the KNX bridge after performing a 'clear configuration' action.
Nice*
    Fixed setting favorite position for the screen devices which does not support this natively.
    Fixed keep-alive support for Domi WSR/WS device, which caused the device to be shown as disconnected in the system.
    Fixed issues with Nice PLN2+ motors controlled as a group using Linked Device.
    Fixed the operation of some group actions causing i.a. malfunctions in scenes.
    Fixed an issue with removing device Domi WSR when the device is inactive.
Other
    Removed a non-functional option (checkbox) for sending notifications on the list of mobile devices.
    Fixed visibility of device name when adding Z-wave devices in the mobile application.
    Fixed tooltips positioning in the interface.
    Fixed the message screen displayed after using the factory reset option in Recovery mode.
    Fixed handling of events from the NICE camera plugin when devices are added via NVR.
    Fixed icons for Sonos and XBMC plugins.
    Fixed errors displayed in the Z-wave tab of the Master hub when using the interface via Remote Access.
    Fixed the input validator for variables.
    Fixed non-functioning group actions in profiles.
    Added real-time refreshing of history entries for Z-Wave Central Scene events and scene-related events.
    Fixed an issue where the reboot sometimes didn't work properly.
    Minor UI/UX fixes.
Profiles
    Fixed problem with triggering changes via profiles.
Quick Apps
    Allowed additional parameters to hub.alert function in QuickApp to keep backward compatibility with old code.
    Variable edit box character limit has been increased from 1024 to 2048.
    Added support for climate zone control functions in QuickApps.
    Fixed restarting the Quick App process when editing it.
    Fixed Heat Activator which stopped working in rare cases.
    Fixed an issue with saving the Quick Apps view to a file when encrypting (applies to QA exported from version 5.191 or later).
    Fixed problem that HTTP responses other than 2xx (300 and higer) don't return response body.
    Corrected validation of variable names to allow editing of existing variable values.
    Fixed an issue with the display of custom icons for remote controllers in Quick Apps.
Scenes
    Fixed an issue that icons other than the default ones are not displayed when selecting profiles in scenarios.
    Fixed refreshing of the scene activity switch in the interface when calling activation/deactivation action from the scene level.
    Fixed inactive color temperature slider for device Elero Lighting TW in scenarios created in the mobile app.
    Fixed problem that net.HTTPClient strips query string parameters in LUA scenes.
    Fixed the behavior of sliders in block scenes for the setColor action, sliders now function independently.
    Fixed an error that block scene with setting Manual mode to "Hold" does not work on HC3L/YH hubs.
    Optimization of scene running.
    Fixed an issue with saving a predefined scenario when some devices are selected.
Update
    Moved the setting related to system version information from the final stage of startup to the earliest possible point in order to reduce incorrect version data in recovery mode.
    Changed the order in which services start during initialization to avoid issues during updates.
    Fixed the behavior of the progress bar when canceling an update download; the progress bar is now hidden.
Z-Wave
    Fixed redundant stopping of Z-Wave3 engine.**
    Fixed the visibility of updates for Z-Wave devices on both engine versions.
* - Does not apply to HC3L (Home Center 3 Lite).
** - Applies only to Z-Wave 3.0 engine.
*** - Fully supported in the upcoming Yubii v2.5.3 application
Security:
    Angular vulnerabilities update.
    Updated Rust toolchain version.
