After update to ZW 3 the Walli Switch led rings don't work anymore.
Have 2 walli switches but switching on the ring that worked before the update, stopped after update.
hub.call(DevId, 'setRingsLightMode', "on", "upper", 0)
Update went oke, had only 1 older Fibaro Eye, to reconfigure, stopt communicating. After reconfiguration it worked as it should
is this a known issue??
The Walli Switch does not support the "setRingsLightMode" action – this action is only supported by the Walli Controller.
For the Walli Switch, you can set the Light Ring using the following parameters:
/monthly_2026_06/image.png.cdc3cbcb1c347f15636b8fec944c743b.png" />
    Sorry for my communication mistake.
    I wrote switch but I mean the controller the FGWCEU-201
    These are the parameters
    Further discussion of the issue has been moved to a private channel.
    After identifying the cause or resolving the issue, the appropriate information will be published.
