m.roszak 780
Hello everyone,
As I bought recently an automated mower, I did some research about integrating it into Fibaro/Yubii.
As the Mova (Dreame) does not officially publish the API I did some testing, based on the information found on different communities I was managed to prepare a QuickApp to actually control it.
It is based partially on REST API but also utylise MQTT to handle the events.
If someone is actually using one of Viax mowers it should be working with any variant.
For now its mostly for testing purposes and supports only one device added to Mova app - API for the vaccums are basically the same so its possible that it will even handle those.
Excercise I did is mostly for testing for now, if someone has any Mova mower feel free to use it - at some point, after some tweaks and comments I will drop it also on the marketplace for everyone to find.
/monthly_2026_06/image.png.d374c966c3ba4051f00da24d7309d072.png">Steps to use:
1. Import
2. Fill email address and password for Mova account in variables
3. Done
If any issues will occur there is also another variable to enable logging (debug) to the console.
Michał
