Good morning,
as we know access to other quickapp function is easy: fibaro.call(id, name, parameters).
I would like to ask the following: is it possible to access (write to) other's quickapp UI field similar way? Alter other quickapp UI field remotely?
8 minutes ago, Łukasz997 said:
Good morning,
So, you must know the component name.
    Thank you very much. I knew that it's possible!
