Good Evening
I am writing to report a critical bug affecting the FGS-213 Single Switch 2 after updating its firmware from version 3.3 to 3.4 on a Yubii Home Pro hub running firmware 5.210.12.
Environment:
- Hub: Yubii Home Pro, firmware 5.210.12
- Device: Fibaro Single Switch 2 (FGS-213), 3 units installed
- Z-Wave Engine: 3.0 (ZW3)
Steps to reproduce:
1. Perform firmware update 3.3 → 3.4 via Settings → Devices → Updates
2. Update completes successfully (status: "Fertiggestellt" / Completed)
3. Click "Reconfigure device" ("Gerät neu konfigurieren") as suggested by the UI
Observed behaviour:
- After reconfiguration, the device's Parameter Template is set to "No" (Parametervorlage: Nein)
- The Parameters tab in the device view becomes inaccessible
- Z-Wave Type drops from 3 to 0, SDK Version drops from 4.24 to 0.0
- Each additional "Read configuration" click further degrades the device profile
- Endpoint XX.1 (Binary Switch, the actual switching channel with energy metering) is permanently deleted from Yubii — not hidden, but fully removed
- Endpoint XX.0 remains and can switch the load, but has no energy metering capability
- Energy reporting (Watt / kWh) is permanently lost until a full Exclude + Include cycle is performed
Important note: The "Reconfigure device" button appears directly in the Updates view after the firmware flash completes, with no warning that it may destroy the device profile. This makes it a high-risk trap for end users.
Additionally, I observed that on two of the three units, the firmware update did not complete at all (devices remain on version 3.3), despite the update process appearing to run.
Requests:
1. Is this is a known bug and do you know if a fix is planned?
2. Anyone knows whether there is a recovery path short of a full Exclude + Include cycle?
I am happy to provide log files, device IDs, or further technical details if helpful.
Thank you for your help.
Edited by Vitruv
0 answers to this question
