Hi  @m.roszak,
I use location panel to get location settings for my HC3 and I notice inconsistency in reporting HC3 name.
Most of the time reported name is actually serial number of the HC3.
After I changed name of my HC3, for some time this new given name was reported, but then after some time again serial number.
Since in the returned json:
there is a "name" and not "serialNo", shouldn't actually contain user given name?
Also, since users can add another location, what those other locations can be used for? I guess, I can add location of my work and then get triggers when I arrive at work?
@Support FIBARO, take a look at this please.
It should report the hcName defined in the settigs of the hub, for some reason its being swapped with serial number as you report.
I confirm on my system that it "reverts" to the serial number by itself - don't know the reason :)
