Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Main features:
NICE cameras Wizard in the mobile binding.
Adding your NICE cameras has never been easier. The brand-new setup Wizard, now available directly in the mobile binding, guides you through the whole process step by step - no hassle.
What's new:
Devices
    Added Smart Start support for DoubleDimmer-Control and On/Off-Control 2 devices.
    Only one NICE camera plugin instance can be running in the system.
Gateway connection
    Added the ability to assign user defined names to slave hubs from within the interface.
KNX
    Added dynamic IP address handling for the KNX Bridge - changing the address does not cause a loss of connection.
    Added routing support.
    Added support for secure connections using certificates in the tunneling and routing options.
Network
    Added the ability to enter longer passwords when connecting to Wi-Fi (up to 128 characters).
Nice*
    Added the option to disable sun impact by setting 0 lux value in Domi WS/WSR device parameters.
Other
    Improved system stability.
Plugins
    Update the Tedee Lock integration to the new API.
Users
    Added the ability to change the hub interface language for installers and support users without having to change the client interface language globally.
Z-Wave
    Z-Wave migration process optimization.
    Optimized reinteview of various devices after migration from Z-Wave 2.0 to Z-Wave 3.0.*
Bug Fixes:
Devices
    Fixed a problem that caused information about a different device to be displayed when adding multiple devices sequentially using Smart Start.
    Fixed a problem where scrolling through the device settings view would delete unsaved changes.
    Fixed the behavior of the hide function in the device binding Wizard.
    Fixed search functionality in the device binding Wizard - searching within categories.
Gateway connection
    Fixed auto-logout functionality from all open windows when controller becomes a slave.
    Restored some of the device status notifications for the slave hub.
KNX
    Disabled favorite position control for roller shutters without positioning.
Nice*
    Fixed misalignment in the translations of the open/close event notifications for the BiDi-Zwave device.
    Incomplete screen temporarily displayed in the Nice device configuration window.
Other
    Added small corrections to the translations.
    Fixed visibility of inactive tabs in the dark user interface theme.
    Fixed an issue where the creation and modification dates of a variable would change after the system was restarted.
    Minor UI/UX fixes.
Quick Apps
    Fixed a rare issue with Quick Apps that use a PIN code for locks following the migration from Z-Wave 2 to Z-Wave 3.*
Z-Wave
    Fixed device synchronization following the migration from Z-Wave 2 to Z-Wave 3.*
    Other fixes to the Z-Wave 2 to Z-Wave 3 migration process.*
    Fixed default tile visibility in the interface for ZW300 switches in version 2.x.*
* - Does not apply to HC3L (Home Center 3 Lite).
** - Applies only to Z-Wave 3.0 engine.
Security:
    Added additional protection for password visibility in the logs of internal services.
    Limited access to some KNX logs for users other than the administrator.
