Vitruv 0
I run a SONOFF SWV (ID 260, battery-powered) for garden irrigation on Yubii Home Pro 5.210.12. Three months flawless — then two problems:
Problem 1 — hub.call() fire-and-forget:
After a command flood (watchdog sending turnOff 50x in 1h — my own bug), the valve stopped accepting any remote commands. Physical button and status messages still worked. Fix: batteries out for minimum 5 minutes (60 seconds not enough).
Question: Has anyone found a way to make hub.call() more reliable for ZigBee battery devices? I now send turnOff 3x with 2s gaps — any better approaches?
Problem 2 — Device parameters:
The device JSON shows
autoOffDefaultTime: 900but the Auto-off toggle in Yubii is greyed out for this device. When the valve is open and I manually enable Auto-off, it works — but resets to off after the valve closes.Question: Is there any way to set device parameters like
autoOffDefaultTimepermanently via Lua (hub.callor API)? The device supports it — Yubii just won't let me activate it persistently.Setup: Yubii Home Pro 5.210.12 · SONOFF SWV · ZigBee · battery-powered
