Nysa joined the community
drzordz1 joined the community
Ok, fixed both in v0.2.71.- 278 replies
Shido joined the community
Hi Jan, I finally had a chance to test latest version 2.70 and it does look pretty god except that effects on grouped lights does not work. Note that effects can be activated only on single lights and so in case of a grouped light Yahue must loop through individual lights of the group and send effect command. On my HUE Festavia light effects are working, but need first to turn it on and then use effect button. If effect button is pressed while light is off then nothing happens.- 278 replies
I'm playing arround with MCP server and have it connected to my Hermes Agent now. I had to updated the server code with the updated sugested in the fix(mcp): echo client protocolVersion in handleInitialize (compat 2024-11-05+) PR on github to get it to work. I managed to get some devices turned off/on and it worked as expected. Next I tried to get my agent to find the device that has to highest energy consumption in the last month, and it failed with the following response I encountered an error when trying to fetch energy data for the last two weeks using mcp__hc3_smart_home__get_energy_data. The system returned a generic "HTTP 500: Internal Server Error", which means I could not retrieve the consumption metrics. The tool only supports fetching energy data based on predefined intervals (hour, day, week, month, year) but appears to be unavailable or restricted when trying to pull complex historical comparisons like a precise "last 2 weeks" analysis. Then i looked into the code behind and notice the following defenition for get_energy_data // Energy Management { name: 'get_energy_data', description: 'Get energy consumption data for devices or the entire system', inputSchema: { type: 'object', properties: { deviceId: { type: 'number', description: 'Optional: Specific device ID to get energy data for', }, interval: { type: 'string', description: 'Time interval (hour, day, week, month, year)', enum: ['hour', 'day', 'week', 'month', 'year'], }, }, }, }, And calling my HC3 API with this // Energy Management Methods private async getEnergyData(args: { deviceId?: number; interval?: string }): Promise<any> { if (args?.deviceId) { return await this.makeApiRequest(`/api/energy/${args.deviceId}`); } else { return await this.makeApiRequest('/api/energy'); } } When looked into the API Swagger there are no API responding to /api/energy/${args.deviceId} So my question is from which HC3 version is these defenitions constructed? Also looking at the energy.json, downloaded from API swagger, there is some detailed defintions for each enpoint/calls, and the one for the energy endpoint (/energy/consumption/device/{deviceId}/detail) looks like this "/energy/consumption/detail": { "get": { "tags": ["energy"], "summary": "Details of energy production/consumption", "operationId": "getConsumptionDetail", "parameters": [ { "name": "period", "in": "query", "description": "Array of time periods for which data is returned", "required": true, "style": "form", "explode": false, "schema": { "type": "array", "items": { "$ref": "#/components/schemas/DateTimeUnitDto" } } } ], I guees this would be the endpoint that comes closest to /api/energy/${args.deviceId}?
Nepo joined the community
- 3
bonjour a tous! je suis a la recherche de l information suivante: peut t on integrer une camera TAPO C 200 C ? merci pour la reponse apportee -
I'm afraid this is not functioning... self.logLevel = DEBUG does not cut TRACE messages. However DEBUG has non-nil value (3).
lvae joined the community
So, there is no local API avaialble so it can be done by QuickApp <-> tado Cloud Api. The problem is that for free users its limited to 100 requests/day so it may not be enough to actually use the device on daily basis. With subscription limit is 20k requests - its costs ~30 euro/year. Accodring to my knowledge there is no QuickApp made yet for this, so you will need to do it yourself or find someone who can do it for you.
karel de munck joined the community
zeynel joined the community
Hi @Dunkigrease, Finder app is replaced with browser link: http://find.yubii.cloud, but only for new gateways. Since HC2 and HCL have reached EOL, I do not think they have any plans to make new finder app.
QA Dist Manager is the preferred way to upgrade/update Yahue https://forum.fibaro.com/topic/80052-qa-dist-manager/ ------- bug in v0.2.69 when watchdog poll was selected. Fixed in v0.2.70- 278 replies
I was recommended to clean them with isopropylalcohol. -
Hi jgab, thanks for the great work on YaHue v2! I wanted to update to the latest version, but I couldn't find the update QuickApp variable in my installation. I created it manually (name: update, value: yes) and saved it, but unfortunately nothing happened afterwards — no update was triggered. Thanks any suggestions-- 278 replies
I pushed v0.2.69. It has 2 main fixes. - buttons and sensors don't republish their events when the QA starts up (thanks @_Marian_) - a new logic to keep the event stream open. Sometimes the event stream opened to the Hue hub goes stale and it's hard/impossible to find out from the net.HTTPClient code. Now there is a quickAppVariable 'watchdog' that can be set to 'time' or 'poll' - 'time', means that we monitor the socket and if we don't get any event for x seconds we restart the QA and reconnects. - 'poll', means that if we haven't got any events for x seconds we poke the hub so it emits an event, if no event back we restart the QA: The time x is set by the quickAppVariable 'watchtime'. The default for 'watchdog' is 'time' The default for 'watchtime' is 1800 (30min) for time, and 60 for poll (1 min) The default is 'time' now to mimic the old behavior, but I would recommend people to try out poll as it is more effective and responsive if the stream goes stale.- 278 replies
- 2
Thanks, I do believe I know what the problem is. Will have a look at it...- 278 replies
Hi, I'm running a Hue Dimmer Switch through Yahue v2 on HC3, and I'm seeing a reproducible issue: roughly every 30 minutes, during what looks like a periodic reconnect/resync cycle, button 4 fires a full Pressed → Released sequence even though nobody touched the switch. Buttons 1–3 do not show this behavior — they're correctly reset to idle. Example from my log (this pattern repeats every ~30 minutes, all day): [08:11:37] status connected [08:11:37] button:1 _ _ [08:11:37] button:2 _ _ [08:11:37] button:3 _ _ [08:11:37] battery 100 [08:11:37] status connected [08:11:37] battery 100 [08:11:37] button:4 _ _ [08:11:38] button:4 Pressed initial_press [08:11:38] button:4 Released Note that buttons 1, 2, and 3 all reset cleanly to _ _ during the resync, but button 4 gets an extra Pressed initial_press / Released pair about 1 second after its own _ _ reset. This exactly matches the last button I physically pressed on the dimmer (button 4, hours earlier) — so it looks like the resync logic is somehow re-emitting the last "active" button state as a fresh press instead of just resetting it to idle like the others. This causes real problems downstream: I have an HC3 scene bound to button 4 (hub.scene("execute", ...)) that gets triggered every 30 minutes by this phantom event, forcing my target scene to run repeatedly without any real button press. Is this a known issue? Happy to provide more logs or test a fix if useful. Thanks!- 278 replies
