0) Create HTTP -> MQTT bridge. (skip if you already have)
  • $ sudo apt-get install mosquitto mosquitto-clients
  • unzip attached mqtt_php.zip to www root folder, for example, /var/www/html/fibaro/mqtt.php
  • call from browser http://192.168.1.28/fibaro/mqtt.php where "192.168.1.28" www server where you unzip attached mqtt_php.zip and "fibaro/mqtt.php" path in your www server
  • here is valid response
1) import attached VD to HC2 MQTT_bridge.vfib
change VD params
change url path for HTTP bridge in main loop
2) create simple HTML test page
<!DOCTYPE html>
<html>
<head>
    <title></title>
    <meta charset="utf-8" />
</head>
<body>
    <div id="log"></div>
    <script src="https://code.jquery.com/jquery-3.3.1.min.js"></script>
    <script src="https://cdnjs.cloudflare.com/ajax/libs/paho-mqtt/1.0.1/mqttws31.min.js" type="text/javascript"></script>
    <script type="text/javascript">
        (function () {
            if (!console) {
                console = {};
            var old = console.log;
            var logger = document.getElementById('log');
            console.log = function (message) {
                if (typeof message == 'object') {
                    logger.innerHTML += (JSON && JSON.stringify ? JSON.stringify(message) : String(message)) + '<br />';
                } else {
                    logger.innerHTML += message + '<br />';
        // Create a client instance
        client = new Paho.MQTT.Client("192.168.1.28", 1884, "clientId");
        // set callback handlers
        client.onConnectionLost = onConnectionLost;
        client.onMessageArrived = onMessageArrived;
        // connect the client
        client.connect({ onSuccess: onConnect });
        // called when the client connects
        function onConnect() {
            // Once a connection has been made, make a subscription and send a message.
            console.log("onConnect");
            // Topic: home/roomID/deviceType/deviceID
            //client.subscribe("home/#"); // all events from all home
            //client.subscribe("home/4/#"); // all events from 4 room
            //client.subscribe("home/4/com.fibaro.binarySwitch/#"); // only binarySwitch events from 4 room
            client.subscribe("home/+/com.fibaro.binarySwitch/#"); // only binarySwitch events from all home
        // called when the client loses its connection
        function onConnectionLost(responseObject) {
            if (responseObject.errorCode !== 0) {
                console.log("onConnectionLost:" + responseObject.errorMessage);
        // called when a message arrives
        function onMessageArrived(message) {
            console.log("Message Arrived: " + message.payloadString);
            console.log("Topic:     " + message.destinationName);
    </script>
</body>
</html>
please change 192.168.1.28 in code on IP address HTTP MQTT bridge
locate on this test page
you should get page like
Spoiler
Good luck!
Other Files from 10der
mainnsto
Could you explain a use for this VD? I think i need it, but i just can't say why :-D
10der
no. TBH I forgot for what I created this VD...
but you can try to read this topic
kh2
Thank you.
where can I call npm? if on HC2 how to get to the command line
best regards
10der
1 hour ago, kh2 said:
Thank you.
best regards
sorry, can't catch ypur question
