0) Create HTTP -> MQTT bridge. (skip if you already have)
- $ sudo apt-get install mosquitto mosquitto-clients
- unzip attached mqtt_php.zip to www root folder, for example, /var/www/html/fibaro/mqtt.php
- call from browser http://192.168.1.28/fibaro/mqtt.php where "192.168.1.28" www server where you unzip attached mqtt_php.zip and "fibaro/mqtt.php" path in your www server
- here is valid response
1) import attached VD to HC2 MQTT_bridge.vfib
change VD params
change url path for HTTP bridge in main loop
2) create simple HTML test page
<!DOCTYPE html> <html> <head> <title></title> <meta charset="utf-8" /> </head> <body> <div id="log"></div> <script src="https://code.jquery.com/jquery-3.3.1.min.js"></script> <script src="https://cdnjs.cloudflare.com/ajax/libs/paho-mqtt/1.0.1/mqttws31.min.js" type="text/javascript"></script> <script type="text/javascript"> (function () { if (!console) { console = {}; } var old = console.log; var logger = document.getElementById('log'); console.log = function (message) { if (typeof message == 'object') { logger.innerHTML += (JSON && JSON.stringify ? JSON.stringify(message) : String(message)) + '<br />'; } else { logger.innerHTML += message + '<br />'; } } })(); // Create a client instance client = new Paho.MQTT.Client("192.168.1.28", 1884, "clientId"); // set callback handlers client.onConnectionLost = onConnectionLost; client.onMessageArrived = onMessageArrived; // connect the client client.connect({ onSuccess: onConnect }); // called when the client connects function onConnect() { // Once a connection has been made, make a subscription and send a message. console.log("onConnect"); // Topic: home/roomID/deviceType/deviceID //client.subscribe("home/#"); // all events from all home //client.subscribe("home/4/#"); // all events from 4 room //client.subscribe("home/4/com.fibaro.binarySwitch/#"); // only binarySwitch events from 4 room client.subscribe("home/+/com.fibaro.binarySwitch/#"); // only binarySwitch events from all home } // called when the client loses its connection function onConnectionLost(responseObject) { if (responseObject.errorCode !== 0) { console.log("onConnectionLost:" + responseObject.errorMessage); } } // called when a message arrives function onMessageArrived(message) { console.log("Message Arrived: " + message.payloadString); console.log("Topic: " + message.destinationName); } </script> </body> </html>
please change 192.168.1.28 in code on IP address HTTP MQTT bridge
locate on this test page
you should get page like
Good luck!
