Initially it was supposed to be a simple Sleep Timer, similar to what we have in TV but later I added some new functions and now it is a simple Scheduler and Sleep Timer in one VD.
Features:
  • Sleep Timer - just set the time after which the device will be turned off or turned on
  • Scheduler - set the time when the the device should be turned on and the time when the the device should be turned off (or in the reverse order - first turn off and then turn on)
  • Filtering devices - you can choose only devices with turnOff action attribute
  • Filtering rooms - you can choose only rooms which have devices with turnOff action attribute
  • _ - change on/off setting time
  • ✔ - add device to schedule
  • - remove device from schedule; triple click to clear the schedule
  • Refresh button - you don't need to touch it. It's called programmatically
  • Displaying the current schedule
  • Logging the events to debug window: add, remove, turn on, turn off
  • automatic support for plugins with turnOff action attribute
  • support for custom virtual devices and plugins
  • instant turn on/off (VD and plugins also)
  • presenting the current device state ( when the device is on, and - when is off)
Customization:
  • change the VD labels to your own language
  • change the texts in the Refresh button code and in the main code:
local lT = {
  newLine = "<br/>", -- change to "\n" if you use this VD on iOS mobile mainly or " " for Android
  scheduledDevices = "Scheduled devices"
       Actually there is a problem with breaking lines in labels, so you can choose new line char. More details here.
  • add your own virtual devices or plugins in main loop code:
local extraDevices = {
-- deviceId,    commandOn,      parameterOn,  commandOff,     parameterOff
  ["335"] =  {  "pressButton",  "2",          "pressButton",  "3"  },
  ["339"] =  {  "setVolume",    "20",         "setMute",      ""   },
icons:
59dba6b6510a0_sleeptimer.png.afca4fa74cbd6e069b76ec44202ea138.pngtimer-128(4).png.a2a23e9ebe1a01b9def7d1e66fbb88b5.pngtimer-128(3).png.a0cf4cf3a0312abdf94c29c8d415d7a8.pngtimer-128(2).png.caadc2e516cde688b414dc3bd9120171.pngtimer-128(1).png.69a65d044c58e16e880c171e48ea72de.pngtimer-128.png.a191a87013d4f5b6beed34f9b5230b13.png
Enjoy...
What's New in Version 1.4   See changelog
VERSION HISTORY:
  • 2017-10-09: v. 1.0 - first release
  • 2017-10-11: v. 1.1 - changed device filtering. Instead of power interface now is checked turnOff action attribute. Thanks @tampiss for helping to find the correct filter.
  • 2017-10-16: v. 1.1a - bug fix for the "Room ▶" button. It was checking power interface instead of turnOff action attribute. Thanks @Figlio for finding the bug.
  • 2017-10-18: v. 1.2 - plugins and VD support. Thanks @petr23 for idea and your code.
  • 2017-10-25: v. 1.3 - instant turn on/off buttons. Thanks @campos for good idea.
  • 2017-10-31: v. 1.4 - changed layout and button icons. Removed 2 rows to save some space. Thanks @Bodyart for good design.
Other Files from szmyk
Ruud NL
Was working fine but now it doesn't respond.
Debug shows: attempt to index upvalue 'jST' (a number value)
Ruud NL
My bad, had a variable SleepTimer in the Variables Panel for a scene that was called SleepTimer. This was causing the error.
Rados
guys, how to install this VD ? tried to upload file but virtual as vfib is not working
thank you in advance
szmyk
@Rados What's the problem? Any error message?
SmartHomeEddy
(Rados has Homecenter 3 in his signature)
Rados
@szmyk just how to upload/install VD as.vfib. if i use add device / others / upload file - there is error message wrong type = device does not exists
szmyk
@Rados Do you have HC2 or HC3? This virtual device supports only HC2.
