Showing results for tags '2 way wiring'.
  1. UPDATE (RESOLVED): Dimmer 2 was faulty. It was working for 1-way wiring but not properly for 2-way. After replacing the dimmer2 with another one, everything is back to normal now. Situation: I have installed Dimmer 2 in the two-way lighting circuit, using two 3-position momentary switches. Added Dimmer Bypass as well. The wiring is as follows: Here is the main parameters for this use case: - Parameter 20 is set to 2 - Parameter 23 is set to 1 - Parameter 26 is set to 0 (but tried 1 as well) Problem: A. When I click, on the first switch, upper button (s1) for the first time, the light comes ON but immediately turns OFF. The second time when I press it again, it is fine i.e. light stays on. Same thing happens on the second switch as well. B. And if I press lower button on the momentary switch ( i.e. s2), lights gets OFF fine. C. Now if I wait for some time and then press the upper button again, same problem happens as described above in point A. D. Same issue happens for my newly created scene where I turn ON all the lights by pressing Fibaro Button. All lights gets turned ON except the hallway light which turns OFF immediately. I would really appreciate if you can help, thanks in advance!
