Showing results for tags 'Dynamic DNS'.
  1. Guest
    Update of DDNS Using Scene
    Hi Guys, First post on here. I've just moved from a Vera to the HC2 to give it a go and find things quite difficult. I had a scene set up on my Vera than ran periodically to update my Dynamic DNS server using a wget function in Luup. I've been mucking around tonight for quite a while using Lua scenes trying to achieve the same outcome with no luck! I'm sure it's easy but can anyone help out? Thanks! Sam.
