Showing results for tags 'Push problem'.
  1. Hi Guys! I´m pretty new to the Fibaro system and have a problem with the iOS push notifiactions in scenes or alarm. I tried the HCL for several weeks and is was horrible. The HCL froze periodically after restart and I wasnt able to connect to the web interface. The scenes als did not work anymore once frozen. That was the reason why I switched to HC2. Now the problem is that I do not get any notification via push. Only emails arrive (in case of an alarm or when set in scenes). There is a second device running Android. There is no problem. All push notifications are shown immediately. For both devices the setting are the same except the account control. The iOS device is an admin device and the one running Andorid has restricted access and control options. Somebody an idea why it worked with HCL and stopped working with HC2? The firmware is the newest available. Hope to get some help here. BTW, I really did try to find an existing thread about this problem but wasnt able to. Thanks Alex
