Hi. I'm about to install 2 qubino dimmers in my kitchen. And with them I can use I2 with a pushbutton as a sensor to trigger other things.
Will it be possible to use it with PLEG as followed?
If sensor1 is triggered an lamp2 is off - turn lamp2 on
If sensor1 is triggered an lamp2 is on - turn lamp2 off
So if I can figure this out I can dim lamp1 with one button and toggle lamp2 with the other
Is it possible with block scene or do I have to use LUA? (wich I'm total novice on)
Hope I made myself clear so u guys can help me
4,051 Beta:
The dimmer modul now have template in hc2 , but the temperature sensor does not work /do not show.
Is there anyone here that knows if there are any parameters that needs to be set to get it working ?
