Showing results for tags 'aeotec multisensor 2'.
  1. Hi, I have recently installed a Fibaro HC2. The fibaro motions sensor works uncomplicated with the HC2, but the Aeotec Multisensor 6 shows up on the HC2 as UV, Temp, light and humidity, but not motion or vibration. The UV sensor widget (w UV icon) appearing in fibaro act as a motion sensor, as it ca be trigged by motion in front of the sensor, and then it shows a 255 value on the UV meter. in a scene, a dimmer can be set to be activated by this . This is however not it should be. I am missing the real motion sensor devise to appear in fibaro. Multiple delete/add procedures have not changed it. I have 2 Aeotec Multisensors 6 that behave in the same manner. The HC2 has 4.056 firmware, two attempts to upgrade to 4.180 have made it freeze and had to be abandoned. Does anybody have a solution for this?
