Showing results for tags 'fibaro hc2'.
Found 4 results
  1. Hello, can anyone know if i can change my wired room thermost de dietrich CDI2 FM51 (picture1) with any z-wave or wifi thermostat. I want to regulate only temperature no other function is needed. The options on old thermost are only Antifreeze, Reduced and Comfort temperature and 7-day schedule. On back of my original De Dietrich wired room thermostat are only two wires connected to J1, nothing else.(picture2) This thermostat controls De Dietrich gas boiler Domoplus DPSM 3-25 LP with Diematic 3 control: manual and sheme in attachment pdf... Have anyone any idea that i could change temperature in fibaro hc2 or in any other way remotely? plan peci.pdf DPSM3-15-25LP DE.pdf FM51 english.PDF
  2. Dear Forum members, After buying a HC Lite i found out that it is not possible to connect it to my Satel alarm, therefore i recently bought an HC2. Now I cant add my Philips hue Lights. When installing the plugin the Hue brige is found but when pushing the button 'search for new lights' and waited for 60 seconds it wont find any of my hue lights. Does annyone know how to add the lights ? Kind regards, Bram Willems
  3. hi all i have the new everspring SP816-1 outdoor motion sensor. i can include with no problem but it doesnt register as the sensor being breached in the interface therefore cannot use as part of scenes. i can however setup a group 2 association to a light and it works as it should. group 1 association has been correctly setup to HC2 as it should be. any thoughts?? thanks
  4. Hi, I have recently installed a Fibaro HC2. The fibaro motions sensor works uncomplicated with the HC2, but the Aeotec Multisensor 6 shows up on the HC2 as UV, Temp, light and humidity, but not motion or vibration. The UV sensor widget (w UV icon) appearing in fibaro act as a motion sensor, as it ca be trigged by motion in front of the sensor, and then it shows a 255 value on the UV meter. in a scene, a dimmer can be set to be activated by this . This is however not it should be. I am missing the real motion sensor devise to appear in fibaro. Multiple delete/add procedures have not changed it. I have 2 Aeotec Multisensors 6 that behave in the same manner. The HC2 has 4.056 firmware, two attempts to upgrade to 4.180 have made it freeze and had to be abandoned. Does anybody have a solution for this?
