Showing results for tags 'air conditioner'.
  1. Version 1.0
    149 downloads
    Since Samsung Plugin doesn't work I decided to write custom Samsung Air Conditioner VD. Requirements: Samsung AC Local PHP server (NAS, RPI, ...) Installation: Copy smarthome folder to your php server Edit/rename Bedroom.php, Living room.php files. For each device you need separate file. In each file: enter IP of your AC device enter token of your AC device To get token follow steps 3.1 - 3.5 from this site. Check if your PHP server is working: http://192.168.0.10/smarthome/samsung-ac/Bedroom.php Of course change 192.168.0.10 with the IP of your PHP server. You should see JSON result with status. Something like this: { "power": "Off", "mode": "Cool", "virusDoctor": "Off", "quiet": "On", "wind": "Fix", "temperature": 22, "currentTemperature": 23, "sleep": 0 } Install Air Conditioner VD Edit Air Conditioner VD: Room name must be the same as your PHP file name without .php extension, e.g. Bedroom Enter Address IP of your PHP server, e.g. 192.168.0.10 Port number of your PHP server, usually 80 Add VD icons and enter icons ID at "refresh" button section: Enjoy...
