Showing results for tags 'alexa multiple hc3'.
  1. Hi, I have multiple HomeCenters (2x HC3 and one HC2) in 3 different homes. Two of these homes are mine, but are in different geographical locations. I've created two seperate amazon accounts, both of which use alexa. The problem I'm facing is that when setting up the Yubii integration on Alexa, I don't have the opportunity to chose which HomeCenter I wish to use. This results in the devices of my main home being all added to my 2nd home (as these devices were previously added to the Alexa over there) and no way at all to ad the new HC3 and al of it's connected devices. This is particularly annoying as Fibaro (or Yubii now, idk) give you acces to multiple HomeCenters from home.fibaro.com/... . But I have no way to select any of these devices when setting up alexa with Yubii. Is there any way to specify WHICH home center to use when connecting Yubii to Alexa with the skill? Thanks for any help.
