Showing results for tags 'aws api gatway'.
  1. Hoping someone can shed some light on this... Trying to send a HTTPS GET request to an AWS API Gateway endpoint. Here's the Lua code (obviously I've removed any privileged information for the purposes of posting here): httpClient = net.HTTPClient(); httpClient:request ( 'https://**********.execute-api.eu-west-1.amazonaws.com/****/***********', { options = { method = "GET", headers = { ['x-api-key'] = '*****************************' } }, success = function (response) fibaro:debug (response.data) end, error = function (err) fibaro:debug ("Error:" .. err) end }) I get an 'Error:Transport endpoint is already connected' message in the debug window. That's not a response from the API (no requests get logged on the AWS side, so the HC2 isn't getting as far as making the request at all.) If I try making a HTTPS request to another URL (like Google for example) it works with no issue. Also I know the API endpoint works, because I can call it from CURL and it does exactly what I expect. It's just from a scene. Seems like others have had the same issue, specifically with AWS API Gateway. Anyone know how to get this to work? Cheers, Dan
