Showing results for tags 'battery change'.
Found 3 results
  1. The smoke sensor does not detect new battery. I take out the old one, press the butten for 3 sec+ and insert the new one. There is a beep but it still shows low batt. It works fine with other smoke sensors. Use last udates on Home center Lite Anye tip what coluld be wrong? Erling
  2. I have 2 FGK101 sensors and they were both reporting low battery. So I replaced the battery but HC2 is just not registering this. I have tried to delete the sensors but it fails to even notice that I am trying to delete this. What is the best way for me to do this? is there a best guide on how to change the battery and get the HC2 to recognise that this has happened?? It seems that HC2 is not reading any signals from the sensors.
  3. Hi, I have problems with door/windows sensor every time I need to change the battery... I change the battery with the magnet off (door/window open), some times is OK some time I need to try to exclude and include again more times before everything work well. This time, for one sensor I wait 2 month before to change the battery starting from the Fibaro messages and now I've tried to change but the sensor doesn't work. The other times as soon I put inside new battery the led was lighting, but this time nothing happen. I've try to check the new battery status and is 3,68V (I have 5 new batteries) and I also tried to use a battery from another working sensor but still nothing happen. I've try to follow the sensor reset procedure, but still nothing happen. This door/windows sensor have also the temperature module DS18B20. Any suggestion?
