Showing results for tags 'caption text'.
  1. Hello everyone! I'm working on solution that should bring easier sharing and installation of scenes and virtual devices for users. What I'm missing is a way how to change button and label 'Name' or 'caption' using LUA code and/or REST API. See picture bellow: @T.Konopka, Please if you know answer to this question can you share it, or of it is not possible with latest version 4.120 can this be added to the todo list for some future release? Really appreciate your help! Sincerely Sankotronic EDIT This is solution to the question provided by @A.Socha: --id of VD id = 105 --contecting to HC2 to get VD who you want modify local HC2 = Net.FHttp("127.0.0.1", 11111) payload = "/api/virtualDevices/" .. id response, status, errorCode = HC2:GET(payload) if tonumber(errorCode) == 0 and tonumber(status) == 200 and response ~= nil and response ~= "" then jsonTable = json.decode(response) --changening caption jsonTable.properties.rows[1].elements[1].caption="testazz" --sending it back local response, status, errorCode = HC2:PUT(payload, json.encode(jsonTable)) end After changing label, slider or button caption please refresh HC web GUI interface page and do Refresh Network data on mobile devices to make change visible!
