Showing results for tags 'changing device parameters'.
  1. Hello, Can anyone tell me how changing, from a QA, the devices parameters? I do have a Neo CoolCam Siren + a Aeon Labs one that I would like to configure from a QA before ringing it. The idea is to configure it to a gentle music when someone ringing, or as an horrible sound in case of breach or security alert I do have tested this, which was natural but that has no impact on the device parameter: function QuickApp:uionOnReleased(event) local deviceID = 292 fibaro.call(deviceID, "setParameter", 37, 2, 1) -- Device 37 | byte syze: 2 | expected value:1 end I have tried to adapt former VD code from HC2, but no way to adapt it local selfId = fibaro:getSelfId(); local port = fibaro:get(selfId, 'TCPPort'); fibaro:debug(port) HC2 = Net.FHttp("127.0.0.1", 11111) jtable = '{"properties":{"parameters":[{"id":1,"size":1,"value":1}]}}' HC2:PUT("/api/devices/" ..port ,jtable) and i'm then stuck looks like i'm sharing the issue (or lets call it "question") with @FBerges Thanks in advance for any recommendation or QA example have a good week end
