Showing results for tags 'dead node'.
Found 3 results
  1. Hi all Since few weeks, I have more and more dead devices ! All my danfoss devices are dead whereas they stay alive during winter. Today it is my aeon lab switch to be dead. It is one of my first device and I never have any problem with it. What could be the reason of this deterioration ? Thanks I'm with 4.070 firmware
  2. Hi to all I have my Sprinklers panels configure with 4 zones in the HCL (Fibaro Relay) . I've add a VCL to increase or stop the iirigation depending on the weather. But i'd like to received any notification if the system doesn´t work properly. The problem that I have is that sometimes the relay go to dead node status and if I do not check the system everyday I will have a problem. Could anyboy help me on this? Thanks in advanced
  3. Hello fibaro people, I keep getting dead nodes from fibaro relay switches. My main controller is in the same room as the switches and the devices are about 8 meters apart. I don't think that the range could be the problem. I'm using HC2 v4.035. Maybe there's any solution for the mentioned problem?
