Showing results for tags 'fibaro lite'.
Found 3 results
  1. Hello, I have a Fibaro Lite and I can not do a reset of the unit. I have followed the manual but the recovery mode does not appear. It only says "Starting services" I haved it of power for for 24 hours and more and It have said "Starting services" for 3 weeks. There have to be a limit of how slow the product can be. Is there a hard reset that do not have to go via recovery? I do not need to save any data. Regards, Bjørn Madsen
  2. Hi All, I'm new to this community and the Fibaro products. I recently purchased a Fibaro Lite unit and want to do something very simple. I have two aeotec multisensor 6 units and want to trigger an email notification when the temperature sensor reaches a set value. I need this email to be sent to an defined email address with a specific subject text and body text. In the scene settings I can only send an email to the Fibaro registered user email address and the subject line can not be user defined. Is there any other way this can be achieved ? Alternatively is there anyway I can call run a ifttt command using a URL call like: https://maker.ifttt.com/trigger/Turn-AC-Off/with/key/xxxxxxxx Any help will be greatly appreciated. Thank you
  3. Hello fibaro people, I keep getting dead nodes from fibaro relay switches. My main controller is in the same room as the switches and the devices are about 8 meters apart. I don't think that the range could be the problem. I'm using HC2 v4.035. Maybe there's any solution for the mentioned problem?
