Showing results for tags 'double relay 2'.
More search options
  1. Hi Everyone, I'm here looking for recommendation or help from everyone who has deeper experience than mine in Fibaro. If i have 10 LED Downlight rated 9W at 240V and i want to make them smart by connecting to Double Relay Switch 2 without external Relay as slave, Can i do that? or How many 9W led can be connected to Double Relay Switch 2? Thank you so much for any suggestions.
  2. I am racking my brain how i can wire a FGS-222 double relay 2 to my 2 wire intercom. I have read the manual and realized it does not have a COM input showing with in the BUS line input. I included a wiring diagram showing the only two connections i have to work with. I know that to activate the door and gate are both dry NO (no contact) connections. powering isn't an issue, its just trying to figure out what wires go where, being it doesn't have COM input... Any pointers or advice would be great! Thanks!!
