Showing results for tags 'eurotronic spirit'.
  1. Hi, I have numerous TRVs set-up in the climate panel and if I want to override the temperature I go into the room section and change the temperature and by default it increases/ decreases for a default of 2 Hours and works as expected. (I wish we could decide what the default time was, but that is a side issue). My issue is that if I ask Alexa to increase the room temperature she does do exactly as I ask, because I have the room section open on my screen and can see the temperature change, but then it immediately reverts back to the schedule set temperature. This also seems to be the case, but not always if I manually set the temperature on the TRV. I am using Eurotronic Spirit TRVs which I am otherwise impressed with. TIA
  2. I just saw the new Eurotronic Spirit. What do you think about it guys? Can someone compare it with the Danfoss LC13 or POPP thermostat? I have read all the reviews and it sound much better then all radiator thermostats so far, even the one from fibaro, becuase as far as i have read it does not support FLIRS mode (well it has a rechargeable battery, which is cool). The Eurotronic Spirit is huge in comparison with the LC13 and POPP thermostat, but the FLIRS and the up facing display is a huge +. Not sure about the battery life though.... Anyone?
