Showing results for tags 'fan speed'.
  1. Hello, I have been using McoHome thermostats for a long time (mh8) and when you set the fan speed there are only three options: high medium and low. But when you set the fan speed from the thermostat itself, there is the auto option which you can leave it on and does its job, not requiring you to change the fan speed every time. Also the parameters are not available for the thermostats even though the thermostats are quite popular and it has been more than a year that I sent the template to fibaro. At least, add the automatic fan speed option so that everything becomes much easier. Thank you!
