Showing results for tags 'fgb-001'.
  1. Hello All, Can someone provide a clear table with regards to Bypass<->Dimmers compatibility? I wonder, if I can I use Bypass ver 1 (FGB-001) with Dimmer FGD-212 or FGD-213 and the opposite- Bypass ver 2 (FGB-002) with Dimmer FGD-211? Thanks Maciej
  2. A bit disappointed that Fibaro decided to discontinue this bypass. Installed a 15w LED ceiling light to find it flashing with Fibaro Dimmer 1, so realised I need a bypass. This is when I find out that its no longer available. So anyone know of a stockist out there? Unless Fibaro want to swap my dimmer 1's for dimmer 2's.
