Showing results for tags 'fgd-211'.
  1. Hi, I found a circuit setup that exactly matches my wiring needs. It is meant for FGD-211. Can this setup also be used for FGD-212. You can find the picture below and also following this link: http://blog.smarthome.hlc24.de/tasterschaltung-stromstossschaltung-relaisschaltung-bzw-treppenlichtschaltung-mit-dem-fibaro-dimmer-im-sicherungskasten/ In my understanding fgd-211's output terminal "O" corresponds to the output terminal of fgd-212. best, ypoosn
