Showing results for tags 'fgs-221'.
  1. Hi, I have bought a FGS-222 Relay Switch (the old one, not the new one with Z-Wave Plus) and I am trying to use it to control my doorbell (make it ring remotely and also know if someone has pushed the door bell switch). I have read the manual and I have seen how Fibaro recommends to use the device (circuit #1, see attachment). The problem with circuit #1 is that I would have to change the existing wiring of the doorbell and I have a very difficult access to it. So, I have been struggling about how to wire this thing without changing the existing doorbell wiring and I have come up with 2 solutions (circuits #2 and #3). I am sure that circuit #2 works but it has some problems (see attachment). Then, the question is: Is the wiring I propose in circuit #3 correct??? Can someone tell me if the S1-Q1 connection could create any kind of problems. I find this OK, but I am not 100% sure. FGS-222-Door.Bell.Alternatives.pdf
  2. ------------- Hmm just figured I need to move the feathers to the opposite side of the switches... Sometimes it helps just to formulate the problem a bit. The template is erranous though, with two parameter 14's that affects each other when set.
