Showing results for tags 'fgwp-102'.
  1. Hello, This week I replaced my VeraPlus with a Fibaro HC Lite. Reason was I use Fibaro devices and sometimes the Veraplus works not as i aspected it should do. The Fibaro Wall Plug FGWP-102 however worked 100% with the Veraplus and it never lost connection, range over more than 10 meters, 100% sending and responding...-> no problem at all. And a Fibaro controller with Fibaro devices: well you can not get a better combination... I thought. But from day 1 Iinstalled the Wall plug to the HC lite I have problems: Installation gives no problem and all parameters are saved (I think). I can use the buttons "On" and "Off" and the wall plug responds. But after 5-10 minutes the wall plug gives a "Communication error" and stops working. Sometimes the button work with a delay. Then I try to "force communication" but then there is an other error "Sent error" (Zenden mislukt). It looks I have no range. The device is situated 1 meter from the controller now and no respons. De-installed and re-installed the device several simes. Everty time same issue: after some time stops working. Even restored the controller back to the factory settings. The Fibaro smokesensors are working OK (I think and hope..) Sorry for my language but I hope you can help me. Greetings Henri
