Showing results for tags 'fibaro-must-die'.
  1. hi! Home_Assistant (6).fqa just for testing. simple integration with HASS. change MQTT server address and all* your devices now in your HASS disclaimer: 1) alpha version. 2) only for ZWave devices 3) now supported only "Binary sensors / Lights / Sensors / Switches" 4) has minor bug with dimmer devices Thanks to: Peter for conception, testing and what he still tolerates me Jan for fantastic fibaroapiHC3.lua Tinman for sha* lib 14.04.2021 all lighting switches (interface lighting) now marked in HASS as "lighting" and you can simple grab this devices. type: 'custom:auto-entities' card: type: entities filter: include: - domain: light state: 'on' - domain: switch state: 'on' attributes: is_lighting_device: true HC3 configuration HASS: check is installed Appendix RTFM: https://www.home-assistant.io/docs/mqtt/discovery/
