Showing results for tags 'hc2 devices'.
  1. I am eager to understand the function of the different "Devices" showing up on my HC2 when installing a Fibaro Switch2 or Dimmer2: A Fibaro Switch 2 will show up in the HC2 as Master + 4 devices. From previous helpful answers I have accepted the Master as merely a "shell". I also see that one of the slave devices is named "Remote", so I assume this is to be used for direct association to a remote of some sort. But why do I see three switches and not just two for each of the S2 and S2 terminals? One of the three seems to be directly controlling one (and just one) of the remaining two. But not the other way round. Switching A will switch B, but not C. And B will not switch A. I´ve tried to figure out the purpose of this arrangement, but ran out of ideas. Any insight into this question will be appreciated! The manual did not provide any help.
